On the crank no start issue it sounds like injectors are getting tired. 30-45 minutes later it has cooled.
Can you pump the fuel filter priming pump to remove air after the engine/truck has sat for a while (i.e. an hour - overnight)?
This will tell you whether air is able to enter the fuel supply. Jim
Contact Me
Content Web Site
Photo Album
TDP Youtube Channel - New!
I removed the edge afew days before it stoped running. I haven't been able to start it sence 05/22/19 and the priming pump is still as hard as a rock. But I do not have hardly any pressure at the fuel rail shraider valve unless I have my lift pump running.
There should be a slightly negative pressure (vacuum) at the Shrader valve with the engine idling - assuming no lift pump.
The following link will provide information for what are normal pressures/vacuum at the Shrader. https://www.thedieselpage.com/review...elpressure.htm
Contact Me
Content Web Site
Photo Album
When I removed my edge (weird problems) I had to reseat some of the pins in the connectors. Apparently they can back out enough to cause your type of problem.
WAM, 2500HD D/A ext cab 4X4, 1997 Suburban 6.5TD K-1500.
I hate to recommend an ether start, but sometimes that is what it takes. Very sparingly give it a little sniff while someone cranks it and see if it goes. If it goes we are back to injectors...
Or, have a tech with a Tech II look at injection system values (rail pressures, etc) while cranking. Maybe give the connectors another look to verify no more pins are pushed... Jim
Contact Me
Content Web Site
Photo Album
