Results 1 to 11 of 11
Thread: Bolts for dual thermostat housing
Hybrid View
    Dec 2010
    SE Texas
    Default Bolts for dual thermostat housing
    Does anyone know the part number or specific size of the 4 bolts that hold the water outlet to the dual thermostat crossover manifold? Have searched this forum and the internet and cannot find them. Also, is there a gasket between the two or just the 2 t-stat seals? Thanks.
    '95 GMC Sierra 6.5TD C2500, reg cab, long box, 2x4, 4L80E, 3.73 ratio, VIN F, L65, 120K. Mods: DE 4" exhaust/crossover, WW2, PMD relocate, Dmax fan/clutch, HP air filter, Fluidampr, B&M Trans/Diff covers.
    Dec 2010
    SE Texas
    Default gaskets
    The bolts are metric... 1.5mm thread pitch x 10mm in diameter, length to suit. It's been a while since I've dealt with a dual stat housing... Jim
    Could you comment on gaskets.....from what I see on these complete kits, it looks like there are several o-rings but no gaskets, except for where the crossover mounts to the block. Am trying to order parts separately to make my own kit to convert my 1995 to a 1997 cooling system. Thanks for the bolt info.
    There are the just two rubber gaskets used around each thermostat. No other gaskets.
    Dec 2010
    SE Texas
    Ya know that's what I thought but wanted to be sure. Thanks for the input.
    The seals with the thermostats are effective. If the housing leaks, it's likely due to crack(s), or porosity in the casting. Almost never does gaskets or RTV cure that. Use minimal recommended bolt torque, and blue thread locker. This prevents warpage and cracks.
