Pretty much covered
Brake booster for a van with the diesel.
Fuel system
Actually the radiator in the van is not big enough to deal with the diesel.
This is not a bang bang done swap.
Doable yesss
Without some mods and work noooooooooooooo
Which tranny is in the van ????
TH 400 OR the 4L80E ???
If the truck has the 4L80E transmission you have another major area to mod to get the tranny talking to the engine.
If the rig has a TH 400 you are in good shape...just need to have the vacuum controller valve on the injector pump to control the vacuum modulator on the tranny.
Likely not, but it could have a 700R4..
Trans throttle pressure cable and bracket needed to control the trans.
A can of worms for sure.
Let us know what tranny is in the van for sure....then we can make more comments that are accurate.
