Results 1 to 8 of 8
Thread: Oil Confusion!
    Mar 2020
    Battle Ground, WA
    Cool Oil Confusion!
    Hello all. My first time on. I own a 2017 GMC Canyon w/a 2,8 Duramax. It was built in the US, but marketed in Canada before I bought it 2nd hand in WA.
    Question: Will Mobil 1 Dexos 1 Gen 2 meet engine specs? I have found conflicting info on-line.
    Thanks.
    Torch
    Welcome aboard!
    NO generation of Dexos 1 is compatible. Dexos 1, Gen 2 is NOT Dexos 2. There is no conflict. If you want Mobil 1 oil, check their site for the latest info, or find some Mobil Series 3000 oil, which is Dexos 2 compatible. It's what I used in our Cruze Diesel, and others around here use in their Cruze and Canyon/Colorado Diesels. Or buy GM Dexos 2 from the dealer. At last check, the dealer list price was on par with the rest of them, and less in some cases.
    Oct 2002
    USA
    Welcome aboard!
    I agree with Dmax. As I understand it but not totally sure, some of the Mobil 1 synthetics supposedly have a Dexos 2 equivalent listed on the container of some of their products.
    I am going to run Amsoil or Mobil 1 in my 2.8 on my next oil change.
    0000000
    Nov 2006
    Orange County, NY
    How often do you change the oil? Book says 7500 miles. Not sure if I like going that long.
    2020 GMC Canyon Diesel
    You can change the oil as often as you like, it's your truck. These later models are not the same old-school oil burners of decades passed. They run MUCH cleaner, inside and out, which means there's less dirty to remove at similar miles as before. Advancements in the engine oils also make longer service intervals practical. They have an OLM (Oil Life Monitor) that's more than simply a mileage counter. They take into consideration the entire operating environment, which includes time, miles and usage conditions. You can change according to the miles, the OLM, or whenever you feel you need to. 7500 miles or 2 years, whichever comes first, is a good baseline for normal use, despite the nostalgic indicators. For less than the cost of one service, you can have the oil tested (probably a couple/few times), for piece of mind.
    Nov 2006
    Orange County, NY
    Thank You DmaxMaverick.
    I found Dexos2 oil on Amazon.. Motul brand if anyone is looking for it.
    For future reference, if you don't want to go to the dealer or off brand, look for Mobil 3000. It's authentic Mobil 1 full synthetic that's Dexos 2 rated. It's hard to find, but worth it, IMO. I used it for over 50K in the Cruze Diesel. It is also what my dealer stocked before they got GM labeled Dexos 2 in stock.
    Jan 2021
    Canada
    dang was searching hours for answers, finally found it. still going to search though.
  1. How Do I Verify Oil Pressure?
    By DennisG01 in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 04-30-2008, 01:01
  2. No Oil Pressure After Oil Change (long post explaining my proceeder.)
    By wthif in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-02-2006, 05:47
  3. NEW TDCO procedures?
    By Aryeh Levy in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 09-25-2005, 06:51
  4. Don't trust tech's changing your oil !!!!!!!
    By mackey_62 in forum Duramax 6600
    Last Post: 06-13-2002, 13:06
