The lines are metal and rubber
Myself i would drop the tank,either clean or replace and pressure test the fuel system,fix any leaks,then run it.
If the old lines don't leak i wouldn't change them,replacement rubber lines may be made of inferior rubber and only last a few years.
I see that a lot new trailers with rotten valve stems made in China,yet old tires from the 80's the stems are still good.
