Plug it in,put a battery charger on the batteries,remover the glow plugs,test them,check your electric fuel shut off solenoid,crank it till you see fuel mist coming from the glow plug holes.
If the glow plugs are good,and you get fuel misting from the holes,replace the glows and give it a try.
