Results 1 to 7 of 7
Thread: 6.2/6.5 Hybrid
    Aside from the A/C HVAC interference Robyn mentioned, the exhaust outlet on the factory 1992-2000 6.5 turbocharger points straight down - directly at the frame rail in the 1980s era trucks/Blazers... Only a few inches separate the turbo outlet and the top of the frame rail. Not a good situation. Some have made it work with complicated bends in the downpipe, but it looks ugly.
    The best solution is to locate a Banks Sidewinder passenger side exhaust manifold made for the 1980s trucks. To that I'd add a Holset HX-35 wastegated turbocharger. Everything else can be easily fabricated and made to look like you began with a commercial kit.
    If your 6.2L heads are in good shape, I'd keep them. For a crawler, low-geared offroader, the small port precups are a good choice anyway, and you won't have to source a set of newer fuel injection lines. Otherwise, you can use a set of 6.5 heads with all of your engine's existing parts (i.e. timing set stuff).
    Jul 2020
    Talking
    Welcome to TDP
    Yes you can do a swap.
    Use the 6.5 heads.
    Change the injectors over to the proper POP pressure for the mechanical Injection pump....
    The 6.5 heads have a different angle on the injector location....
    You will likely need to scare up a set of 1992/93 6.5 injector lines to finish off the swap.
    Now....the one caveat.........
    If you have air conditioning installed (Factory type) the turbo will hit the AC box
    Without AC and things can be fit in quite nicely.
    You don't have to fool with the timing cover, water pump or any of that stuff.
    Swap the heads (Use the Felpro gaskets and new head bolts)
    Swap the 92/93 injector lines
    Do your exhaust
    Good to go
    The original Banks turbo kits for the Square body trucks made very similar if not better power with the 6.2 than the factory 6.5 did.
    The Banks turbo kits had better exhaust flow....
    You might be better off scaring up a Banks kit and going that route...
    No need to rip the engine down and or buy different fuel lines and such.
    Just sayin
    Have fun
    Keep us in the loop....always great to see these venerable older rigs being massaged...
    Thank you both for that plethora of knowledge! I have a friend that has the banks kit minus the turbo he is selling me for $400.
    My next question is... How do I post pictures?? Hehe
    Jul 2020
    United States / Santa Cruz, CA
    Default Friend...
    If you dont buy your friends kit, lemme know... Ill buy it, seriously!
  1. What in the US are there quality 6.2/6.5 repair shops?
    By Madrugador in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-15-2020, 13:28
  2. Bypass cooling for the 6.2/6.5
    By More Power in forum 6.2L/6.5L Diesel - Upgrades & Service Questions Answered
    Last Post: 05-15-2017, 10:29
  3. How-To: Remove a stuck 6.2/6.5 oil filter
    By flomulgator in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 05-06-2012, 10:30
  4. 2009 Chevrolet Silverado Hybrid
    By More Power in forum Industry News
    Last Post: 11-14-2007, 12:59
  5. New 6.2/6.5 Tech Forum
    Last Post: 10-12-2007, 08:03
