Results 1 to 2 of 2
Thread: 4bg1t to ax15 jeep swap
    Jul 2020
    bc canada
    Default 4bg1t to ax15 jeep swap
    im swapping a 4bg1t motor from an isuzu generator into a tj and was wondering if anyone had any info or experience with it...
    pretty uncommon swap from what i hear.
    i know there are adapter kits from an SAE 3 flywheel housing, which from what i can tell is what the 4bg1t comes with, to the AX15 transmission. but that doesnt solve the flywheel issue.
    i understand that i may have to get an adapter made, does anyone have any imput on how best to measure the distance between flywheels so that i can get one made?
    i havent yet pulled both flywheels and housing apart, the jeep 4.0L and the isuzu, so there may be issues with imput shaft spline count...? ill know later this week..
    am i going about this the wrong way?
    cheers for any imput.
    -J
    Welcome aboard!
    I think you're overthinking it. Once you have a flywheel that fits the crank, and pressure plate that fits in the housing, you only need a disc with the correct spline, diameter and thickness to work. Clutch discs, even custom, are relatively inexpensive. You may have to modify the throwout, but that should not be a significant issue.
  1. 2003 Jeep TJ 6.2 Detroit Diesel swap.
    By Rumpelstiltskin in forum Diesel Conversions & Swaps
    Last Post: 12-05-2017, 19:43
  2. Jeep J20 6.5 swap tranny/TC question
    By jteckmann in forum Diesel Conversions & Swaps
    Last Post: 10-26-2007, 22:20
  3. 6.2 swap into a 1990 yj jeep
    By jdavey5454 in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 04-04-2007, 10:20
  4. Jeep Wrangler 6.2L swap is cancelled!
    Last Post: 03-04-2007, 21:01
  5. Jeep Wrangler diesel swap
    By arveetek in forum Diesel Conversions & Swaps
    Last Post: 09-02-2006, 17:19
