Results 1 to 2 of 2
Thread: Cooling air going wrong direction?
    Jul 2020
    USA Colorado
    Default Cooling air going wrong direction?
    Newbie here, and tried searching to no avail.
    1995 GMC Sierra 3500 6.5 diesel turbo.
    1 Standing at the front bumper, the cooling fan blows TO YOU, that is the air blows from the engine thru the grill to the bumper/?????? Am I crazy? or what, I'm closer to 82 than 81 and have never seen that; for the time being, I believe something is wrong, like maybe wrong fan with blades turned/slanted backwards??????
    2 Standing at the front bumper, which way does the engine rotate?
    Thanks,
    LarryR
    Welcome to TDP
    Well now....THE FAN IS SUPPOSED TO SUCK OK
    A couple things come to mind.
    Serpentine belt not installed correctly (Not likely....may not be possible)
    Someone installed a fan blade for a V belt driven setup.
    A serpentine belt system turns the fan backwards from the crank rotation....
    Get a helper to bump the starter while you watch the rotation of the fan.....
    BE SAFE AND KEEP AWAY FROM THE BLADE
    I suspect someone put the wrong blade on OR installed it backwards...
    Here is a picture of an actual factory type 6.5 diesel fan looking at the blade from the engine side (Toward radiator)
    Compare this to yours..
    If memory serves me...there is a ROTATION ARROW on these blades
    Looking from the front AT THE TRUCK the fan SHOULD rotate COUNTER CLOCKWISE
    Let us know what you find....
  1. 6.5 Engine Cooling Solutions
    By More Power in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 05-17-2005, 16:02
  2. My truck flows more air than your truck
    By gmctd in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-10-2004, 18:22
  3. Air Flow Requirement for the 6.5TD
    By Spindrift in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-10-2004, 21:39
  4. 6.5TD STALLING - Air in Fuel Filter Housing
    By Mudtrekker in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 12-05-2003, 04:23
