Thread: Fuel filter life
    Dec 2005
    Klamath falls/keno Oregon
    Default Fuel filter life
    How is the “change fuel filter” warning tripped?? I have 2000 miles on my filter.
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Dec 2005
    ok then.......
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    You'll get the same answer from a GM tech.
    Some are usage based. Some are mileage based. Some are time based. Some are (differential) pressure based. Some are two or more of the above. I don't know what it is for the 2006, and it may not be the same for all 2006 models (engine series transition year).
    You are saying, it's been 2K miles since your last filter change, and it's messaging that it wants a change? If so, either you didn't reset the counter at your last change and it thinks it's due for the change you did 2K ago, or it's usage and/or pressure based and something's caused it to think you need another change. Do you recall if you reset it at the last change? If you're fairly certain there's no problem and it runs normally, just reset it and move on until the next time. Or change it and reset it. I doubt it makes much difference either way, short of the cost of an early change.
    Maplesville, AL - Home Base
    I have never had a filter related issue with my 2006 LBZ. How long does my fuel filter last? 10,000 miles every time. I watch the DIC and at 10,000 miles it is usually telling me 30-50% usage. I don't care, I change the filter at 10,000 miles and reset. 210,000 miles and going strong. Filters are cheap, engines and fuel systems are not.
    Ed
    KM4STL
    Dec 2005
    I wouldn’t bet my virginity that I reset it, but ...I don’t have the fancy “DIC” system on my truck..I’ll just replace the filter..I did put a strong injectors/fuel system cleaner in the tank 2000 miles ago....
    Thanks all..
    Hummer wheels :^)
    dual lift pump
    Banks air intake
  1. Stalls but has new relays & filter - 97 Suburban 6.5TD w/ Heath Mods 5 yrs now
    By 97Suburban in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 09-24-2010, 15:01
  2. Please advise: 2006 Dmax died on interstate
    By ccole in forum Duramax 6600
    Last Post: 06-18-2007, 10:47
  3. Ultra Low Sulfur Diesel - Regs & Discussion
    By More Power in forum Industry News
    Last Post: 09-27-2006, 09:44
  4. Replacing mechanical lift pump
    By Doug Towne in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 04-30-2004, 12:35
  5. Bad fuel - watch out! (long)
    By Steve StLaurent in forum General Diesel
    Last Post: 06-29-2001, 20:35
