Results 1 to 7 of 7
Thread: no start trouble
    Sep 2020
    France
    Default no start trouble
    Hi everybody,
    my name is Romuald and I live in France . I bought my dream car (GMC C1500 suburban sierra classic 6.2 diesel 1982 , TH700r4) few months ago ( january 2020) .
    It had many different little issues to solve , but nothing difficult.
    It has a manual button for glow plugs . i fixed an issue due to a too small relay (15A) , and replaced it with a 120A.
    then the glow plugs work correctly.
    My new problem since july is this :
    - sometimes it starts very strong and correctly
    - But sometimes, when i turn the key ignition to ON (not to activate the starter) , evrey electric part are off (no starter, no Glow plug possible, no interior lights or dashboard lights nor frontend light or signal . nothing....)
    I need to let the truck few minuts or few hours , then it will start correctly.
    I changed the ignition switch just in case, but didn't fix the problem.
    I wondered if it was only if the engine is hot... mostly; but once I had the problem in the morning by a cold start (in july , not so cold....)
    If anybody has an idea .
    it's driving me nuts .....
    thanks
    Dec 2003
    Yukon Canada
    Hi Romuald
    Welcome
    Check your grounds,make sure you have a good ground to the engine,and a good ground to the block.
    Nice truck,i just got a 88 Suburban back that was my mom and dad's years ago.It was an official veihical of the 1988 Winter Olympics.Mine is gas but that will change.
    Sep 2020
    France
    Hi Romuald
    Welcome
    thank you, i'll look my ground to the engine , but (sorry for my english , sometimes poor... ) what do you name 'block" ? is it the fuse box ?
    her are some pictures 1st when I baught it. second, now. sorry for the size...
    Sep 2020
    France
    thank , i'll look for the ground.
    what do you call "ground to the block" (I'm not sur of my technical englis...)
    Dec 2003
    Yukon Canada
    Hi Again
    Block i referred to is the engine block.
    A friend of mine just had starting problems on his GM pickup.
    He changed the ignition switch,starter,and spent a few day working on it and in the end the ground straps from the frame to the engine block were disconected.
    Sep 2020
    France
    Hi Again
    ok , I understand. i'll look for it this week-end .
    thanks
    i'll let you know
    Sep 2012
    malvern, arkansas
    Was wondering if you got this fixed I was going to say ignition switch that is bolted to the under side of the steering column
  1. Help getting a 6.2 to start...
    By jeeper in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 07-03-2012, 11:17
  2. Another hard (luck) start story
    By ekw in forum Duramax 6600
    Last Post: 11-24-2011, 09:10
  3. Won't start. Ideas needed-Please take a look
    By restoguy in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 04-23-2008, 18:57
  4. '01 Dmax getting harder to start
    By chessy56 in forum Duramax 6600
    Last Post: 01-23-2008, 18:33
  5. Does not start! HELP
    By kochwi in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 10-11-2004, 19:58
