Page 9 of 9 FirstFirst ... 56789
Results 161 to 169 of 169
Thread: 6.2 Banks Sidewinder Turbo Build
  1. #161
    Jul 2020
    I swapped out the 6.2 oil filler to the 6.5 oil filler because I am going to a 6.5 CDR set up for the snorkel.
    For just the rest runs, I installed a 0-60 oil pressure gauge.
    I am now experimenting with getting a smaller diameter tensioner pulley so it does not hit the larger water pump pulley. Note OEM 6.5 tensioner pulley is 3” diameter.
    I ordered a new 6.5 CDR passenger side valve cover. I do not want to take too many parts off of my running spare 6.5 because I will be doing an 18:1 build in the future if the block and heads are good on it.
  2. #162
    Feb 2012
    Pauline, SC
    By any chance do you live in Wolf Point Mt ?
    1993 Chevy K3500
    like us on Facebook
  3. #163
    Jul 2020
    Quote Originally Posted by sctrailrider View Post
    No. Bozo area. Is wolf point where you are from?
  4. #164
    Feb 2012
    Pauline, SC
    No, just sold a set of 18:1 pistons to someone who lived their...
    1993 Chevy K3500
    like us on Facebook
  5. #165
    Jul 2020
    Yea that was not me. So the rumor is the 6.2 pistons are thicker then the 6.5 pistons and would be a better option to do the 18:1. Do you sell sets of 6.2 18:1 pistons?
  6. #166
    Feb 2012
    Pauline, SC
    No but if you want them machined and or coated I can do that.....
    1993 Chevy K3500
    like us on Facebook
  7. #167
    Jul 2020
    Ok. I have 2 more motors to build up after this one. I’ll give ya a call when it’s 18:1 time for sure!
  8. #168
    Jul 2020
    Got off work today and spent 10 minutes taking off the driver side exhaust with the sawzall. It’s painful to see myself tossing it. After all it is 3” stainless with flow master.
    I got started on removing the Oem motor crossmember and just as I was on the last rivet, wife came out and said it’s dinner time and I had to go run some errands for her. Now it’s dark and cold. Maybe tomorrow I’ll get to install the ORD motor crossover. :-D
  9. #169
    Helluva sweet job on the 6.2.....I Enjoy the photography
    The old 6.2 used to have an oil baffle inside that stopped the fill tube from leaking around the rubber grommet.
    GM decided that the baffle cost too much and a bit of oil puking was OK
    (1) 2007 Chevy Avalanche
  1. 85 6.2 w/banks turbo to 94 6.5 turbo
    By fatboy6949 in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-23-2014, 11:58 PM
  2. Will a factory 6.5 turbo system work on an 80's 6.2?
    By More Power in forum 6.2L/6.5L Diesel - Upgrades & Service Questions Answered
    Last Post: 11-12-2013, 12:10 PM
  3. Banks kit on high milage 6.2?
    By darkroad in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 06-01-2006, 01:08 AM
  4. How to turn down Injection Pump off engine, & TURBO ?'s
    By john8662 in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 11-13-2003, 10:10 PM
