The monitor should show correct battery voltage, regardless of solar panel input. Even with zero solar panel input, the monitor should display what is actually in the batteries.
Since you say the actual 12V system appears to be functioning fine, I would suspect either a faulty monitor, or a bad/corroded connection between the monitor and the batteries. Typically the monitor is a separate component from the charge controller. Measure the voltage at the controller. If the voltage is normal there, then check connections between the monitor and controller. If everything seems normal there, a faulty monitor is likely.
