Results 1 to 6 of 6
Thread: P0402 code
    Dec 2005
    Klamath falls/keno Oregon
    Default P0402 code
    Can I get a list of things to look at?? All clamps are tight..MAS look fine, but what would I clean it with besides MAS cleaner?
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Try some electrical (contact) cleaner. Don't use Brakekleen (can damage the plastic and potting). Some aftermarket intake systems can make them more sensitive to otherwise normal conditions, such as a dirty air filter, which can alter the internal turbulence enough to cause faults. Also check for air leaks anywhere downstream from the MAF, as well as the connectors and harness.
    Dec 2005
    Thanks..I have a Banks air intake...is it worH it to remove the EGR and clean it?? They are $250 on ebay for a new one..
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    I didn't look up the code, but yeah. Clean the EGR before dropping a bunch of cash. You can use Brake Kleen on that, once you get all the chunks off.
    Dec 2005
    I pulled the MAS and found the horizontal ( The large one in the picture) was dirty.. Cleaned it and cleared the code..will come back and update...thanks
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Dec 2005
    SEEMS TO BE ok, but I started another thread the pro’s and OP’s of pulling the EGR
    Hummer wheels :^)
    dual lift pump
    Banks air intake
  1. j code intake on c code engine
    By Vin82k3500 in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-22-2011, 07:47
  2. WTF!?!? Overboost problem again!
    By Shed in forum Duramax 6600
    Last Post: 05-26-2007, 22:07
  3. Crank position sensor code
    By spark3542 in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 09-11-2006, 12:05
