Thread: Cooling fluid ??
    Dec 2005
    Klamath falls/keno Oregon
    Default Cooling fluid ??
    60k since I change it...green or orange fluid??
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Do you need to change it? Dexcool (OEM) is rated for 5 years or 150K miles, or forever. At any rate, don't use green. Use only Dexcool, or a quality brand labeled "meets or exceeds Dexcool", not just a coolant that isn't green. Premix or 50/50 with full strength and distilled water.
    Dec 2005
    It’s been 3 years and 61k miles....has orange in it now
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Quote Originally Posted by spongebob View Post
    Have a look at the following article about changing the Duramax water pump. There's a mention of the coolant and a couple photos that might interest you...
    https://www.thedieselpage.com/durama...xwaterpump.htm
    Dec 2005
    Hummer wheels :^)
    dual lift pump
    Banks air intake
  1. Bypass cooling for the 6.2/6.5
    By More Power in forum 6.2L/6.5L Diesel - Upgrades & Service Questions Answered
    Last Post: 05-15-2017, 10:29
  2. allison fluid cooling lines 2001
    By gmc sierra in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 08-26-2015, 17:30
  3. Allison Fluid change
    By ItsMrBill in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 10-13-2002, 11:30
  4. Allison Fluid change
    By ItsMrBill in forum Duramax 6600
    Last Post: 10-09-2002, 08:05
