Thread: EGR removal pro’s/con’s
    Dec 2005
    Klamath falls/keno Oregon
    Default EGR removal pro’s/con’s
    I searched “egr” and got nothing, I’d like to know about this valve, I threw a P0402 code and I’m not looking forward
    To pulling to clean it or replace it. And if Block it I don’t not the “check engine” light to come on because it’s gone..
    I have cleaned the MAS it was a bit oily, and cleaned the after market (Banks) air cleaner cleared the code and it’s Ok now
    But....
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Cleaning the EGR is a maintenance cycle item, and more often with power mods. Also, K&N (as well as any oiled gauze) air filters are notorious for fouling MAF's. Fortunately MAF cleaning is a piece of cake.
    Dec 2005
    I know, I cleaned it...
    Hummer wheels :^)
    dual lift pump
    Banks air intake
  1. exhaust manifold bolt removal and head removal
    By BAD5oh in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-17-2008, 17:26
  2. Oil pan removal
    By 6 and 1/2 liters in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 05-23-2006, 17:11
  3. Oil Pan Removal
    By Subzilla in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-08-2004, 08:58
  4. '03 Cat removal
    By tysmith in forum Duramax 6600
    Last Post: 07-17-2003, 22:51
  5. Pin removal from ECM
    By chuntag95 in forum Duramax 6600
    Last Post: 11-06-2002, 09:48
