Thread: Difference between bosch 0430211097 and Bosch 0432217276 injectors
    Nov 2020
    Sweden
    Default Difference between bosch 0430211097 and Bosch 0432217276 injectors
    Hope you all doing ok in these crazy times...
    I have a set of bosch 0430211097 injectors in my 1995 yukon 6,5 turbodiesel.
    I'm about to change them but the only ones I can source in my nick of the woods( Sweden) is a set of Bosch 0432217276...
    Now I'm wondering what the difference is?
    Thanks
    Nov 2020
    Sweden
    Hello again.
    Any suggestions where i should order new ones? Is only Bosch or is there any aftermarket ones that are any good?
    Thanks
    It looks like the 276 number is the new part number and the 097 is the body part number. You can get an 097 body with either different injector pressures for either the NA or Turbo engines. So you probably want the 276 version for your turbo.
    http://www.hummerknowledgebase.com/fuel/injnos.html
    Diesel Page Member #2423
    Nov 2020
    Sweden
    Thanks for the info!
    I order a set of stock bosch injectors for 6,5 turbo from heath diesel. Hope they will be able to ship those to Sweden in these crazy times!
  1. Bosch 973 Injectors for Sale - New/Never Used
    By chestatee in forum TDP Classified ad forum
    Last Post: 07-15-2012, 03:37 PM
  2. bosch injectors
    By jjmoore in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 02-28-2012, 01:36 AM
  3. bosch injectors
    By jjmoore in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 02-28-2012, 12:49 AM
  4. Bosch 6.5 TD Injectors
    By Bobbie Martin in forum TDP Classified ad forum
    Last Post: 04-02-2006, 07:31 PM
  5. Bosch injectors
    By MikeC in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 11-21-2003, 09:59 PM
