Results 1 to 6 of 6
Thread: 6.5 Alternator question
    Jul 2020
    Default 6.5 Alternator question
    Is this prong on the 6.5 isolated ground or a positive terminal?
    Positive charge lug off the rectifier. The alternator is grounded through the housing.
    Jul 2020
    Ok thanks! Does the 6.5 tach reading come from the alternator?
    Yes. It also makes the pulley size (crank and alt.) critical to accuracy.
    Jul 2020
    Ok. The 4 wires that are on the connector, what do they do? Color codes?
    I can't help without a specific application and a diagram, and I have neither. Typically, the alternators are either 2 or 4 wire connectors (4 place, with only 2 used, in the 2-wire). One is the field exciter, the others are for voltage regulation and the tach (if the correct application). I don't know the colors, but I bet google does.
  1. Alternator Question
    By CaptRon010 in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 12-20-2007, 18:33
  2. alternator question
    By markman2 in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 09-20-2006, 10:24
  3. Alternator cable question
    By Fredeberle in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 10-16-2004, 08:45
  4. Alternator question ??????
    By Boonbltz in forum Duramax 6600
    Last Post: 05-06-2004, 15:05
