Results 1 to 2 of 2
Thread: Temperature gauge issues
    Oct 2020
    Regina Saskatchewan canada
    Default Temperature gauge issues
    Hello I have a 1989 Chevy Silverado 1500 2 wheel drive 6.2 diesel I’ve been have some trouble with the temp gauge the last few days I have the half crescent style gauges now what’s been going on is once the truck is running the temp gauge slowly pegs out to hot now I know the engine isn’t over heating I just replaced t stat about a month ago and because of the gauge problems I’ve been the last couple days I just replaced the temp sender for the gauge and still doing the same thing if you unhook the temp sender wire gauge drops right down to nothing hook it back up pegs full when truck is up to temp when you start the truck first thing in the morning temp gauge slowly rises to Peged hot I have no reason to believe the truck is actually over heating it runs fine I can grab the rad hoses when trucks up to temp and they are not that hot also I have an inferred thermometer I can point at engine and it tells me the truck is not over heating as well Any insight would be appreciated as to what direction to know next thanks
    Make sure the cooling system is bled and all air is out of the system. If there is an air pocket around the temp sending unit, it will cause this symptom.
  1. 6.5L temperature issues
    By Jle1208 in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 02-25-2019, 16:42
  2. Transmission Temperature Gauge
    By AugustDiesel in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-25-2017, 05:21
  3. Oil Temperature Gauge
    By moss6 in forum Duramax 6600
    Last Post: 07-27-2008, 08:53
  4. Oil temperature gauge
    By Mark Rinker in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 06-10-2007, 10:07
  5. temperature gauge
    By mhagie in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 04-24-2004, 16:07
