Results 1 to 9 of 9
Thread: Help..! 95 6.5 Chevy Cuts Out... what would you do?
    May 2003
    Cottonwood, Ca
    Default Help..! 95 6.5 Chevy Cuts Out... what would you do?
    My 1995 Chev Silverado truck 6.5L. Starts up, idles, but cuts out as you accelerates with smoke.
    As SOON as the "Check Engine" light comes on, it's smooth as silk. Drives down the road and accelerates to full rpms with no problem at all.
    As soon as I stop- shut the engine off. Restart- the check engine light is off and it won't accelerate without cutting out and smoke. Sometimes in a few seconds the check engine light comes back on and the truck runs great, but every time I shut the engine off it does the same thing.
    What would you do yo fix this?
    250k miles. Don't know if the injection pump has been replaced. I replaced the lift pump and some other items.
    Any input is much appreciated. Thanks in advance.
    2004 Dodge Ram 4x4 Cummins
    1995 Chevrolet 6.5 4x4
    1985 GMC 6.2 4x4
    Quote Originally Posted by jpgreen View Post
    First thing to do is check for DTCs. All you need is a paper clip.
    https://www.thedieselpage.com/members/trblcode.htm
    May 2003
    Cottonwood, Ca
    Thanks- that page won't let me in. I guess it's for members only.
    1985 GMC 6.2 4x4
    May 2003
    Cottonwood, Ca
    I found some info on YouTube.
    1985 GMC 6.2 4x4
    May 2003
    Cottonwood, Ca
    Does anyone have a code chart? It's hard to follow but mine looks like it's reading a 78, 53, 63, 54.
    1985 GMC 6.2 4x4
    IIRC, they should come in numerical order from low to high.
    I've not seen any documentation that states that, but I've never seen one that didn't (and I've seen a LOT). If the numbers are in the order displayed, there's a good chance of error in the reading. If so, it's a good idea to check again.
    I was always told cure the first code listed then clear the rest and retry to see what comes back. Often the first code causes the following codes.
    I think they're numbered such that that rule is also true.
  1. 4x4 cuts out
    By allformike in forum 1982-2000 C/K Truck & SUV Chassis & Drivetrain
    Last Post: 02-16-2008, 23:09
  2. Hot outside, she cuts out
    By ChuckZ in forum Duramax 6600
    Last Post: 07-18-2007, 12:21
  3. CUTS OUT AT SPEED
    By MIKE WIENER in forum Duramax 6600
    Last Post: 11-29-2004, 16:01
  4. Engine cuts off.....
    By Big Bad in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-11-2004, 14:49
  5. engine cuts out from stop
    By durahaulin in forum Duramax 6600
    Last Post: 04-09-2003, 00:44
