Results 1 to 5 of 5
Thread: FOR SALE: Large lot of 6.5l parts
    Sep 2013
    Dillon, Montana
    Default FOR SALE: Large lot of 6.5l parts
    FOR SALE: Hello I am going a new direction with my 1986 K30 square body project so selling all the 6.5l parts!
    - 3 DB2 4911 IP’s, one with 44,000mi, two with unknown mileage, at least two sets of IP lines
    - 1 DB2 5119 IP
    - 1 ’98 Electronic IP
    - 2 ’98 engines parts only , probably good heads on 44,000 mi engine it still ran great but had a coolant leak
    - 1 ’96 engine (ran out of oil) parts only
    - 1 dual mass flywheel & clutch (not sure if its good or not)
    - 1 good clutch & flywheel
    - 2 flex plates
    - 3 gear reduction starters
    - 2 direct drive starters
    - 2 dual thermostat manifolds ( one modified to work with Mechanical IP )
    - 3 GM Turbos one looks fairly new
    - 2 sets of GM exhaust manifolds and cross over pipes
    - 1 aluminum radiator
    - Banks sidewinder kit with (banks turbo, passenger side exhaust manifold, air filter housing, crossover exhaust)
    - GM v-belt damper for a 6.2l hard to find low mileage
    - 3 sets of accessory drive brackets plus serpentine belts
    - 1 good vacuum pump serpentine drive
    - 1 good newer fuel filter housing that does not leak
    - 2 9 blade steel fans
    - 1 good oil cooler for ’93
    - several sets of injectors one set with 44,000 mi
    - fan shroud for ’93
    - 2 glow plug controllers
    - Volumes I,II&III of The Diesel Page 6.5l Turbo Diesel manuals
    I am not interested in selling individuals parts, located in southwest Montana for pickup only. I would like $1500 but it all needs to go, so make an offer. This list certainly wasn’t everything butif its related to a 6.5l it goes with the sale.
    I would be happy to email pictures of everything.
    Thanks,
    Scott
    iowafarmboy0@gmail.com
    Nice stash of parts,wish i was closer
    Someone is going to save a lot of searching time buying up this lot.
    Yes, that's a good buy for everything you have listed there. Good luck, hope it all goes to a good home!
    1995 K1500 Tahoe 2 door, 6.5LTD, NP241, 4L80E, 3.42's, 285/75R16 BFG K02's; Kennedy OPS harness, gauges, Quick Heat plugs, and TD-Max chip; Dtech FSD on FSD Cooler; vacuum pump deleted, Turbo Master, 3.5" Kennedy exhaust, F code intake, '97 air box; dual t/stats, HO water pump, Champion radiator; Racor fuel filter; 368K miles and running strong!
    Jul 2020
    Interested in a lot! Live in Belgrade. Can I come take a look
    Jul 2020
    Listing closed. Pleasure to meet and do business with you!
  1. Parts for sale
    By Yehoshua in forum TDP Classified ad forum
    Last Post: 05-04-2017, 04:20 AM
  2. 1996 K1500 parts or project for sale and spare parts
    By redbird2 in forum TDP Classified ad forum
    Last Post: 06-06-2008, 04:33 PM
  3. Used & New Parts For Sale
    By wthif in forum TDP Classified ad forum
    Last Post: 02-21-2008, 06:50 PM
  4. 6.5 Parts for sale
    By damork in forum TDP Classified ad forum
    Last Post: 01-04-2008, 09:14 PM
  5. 6.2L PARTS - FOR SALE
    By TanM998 in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 10-28-2004, 11:42 AM
