FOR SALE: Hello I am going a new direction with my 1986 K30 square body project so selling all the 6.5l parts!
- 3 DB2 4911 IP’s, one with 44,000mi, two with unknown mileage, at least two sets of IP lines
- 1 DB2 5119 IP
- 1 ’98 Electronic IP
- 2 ’98 engines parts only , probably good heads on 44,000 mi engine it still ran great but had a coolant leak
- 1 ’96 engine (ran out of oil) parts only
- 1 dual mass flywheel & clutch (not sure if its good or not)
- 1 good clutch & flywheel
- 2 flex plates
- 3 gear reduction starters
- 2 direct drive starters
- 2 dual thermostat manifolds ( one modified to work with Mechanical IP )
- 3 GM Turbos one looks fairly new
- 2 sets of GM exhaust manifolds and cross over pipes
- 1 aluminum radiator
- Banks sidewinder kit with (banks turbo, passenger side exhaust manifold, air filter housing, crossover exhaust)
- GM v-belt damper for a 6.2l hard to find low mileage
- 3 sets of accessory drive brackets plus serpentine belts
- 1 good vacuum pump serpentine drive
- 1 good newer fuel filter housing that does not leak
- 2 9 blade steel fans
- 1 good oil cooler for ’93
- several sets of injectors one set with 44,000 mi
- fan shroud for ’93
- 2 glow plug controllers
- Volumes I,II&III of The Diesel Page 6.5l Turbo Diesel manuals
I am not interested in selling individuals parts, located in southwest Montana for pickup only. I would like $1500 but it all needs to go, so make an offer. This list certainly wasn’t everything butif its related to a 6.5l it goes with the sale.
I would be happy to email pictures of everything.
Thanks,
Scott
iowafarmboy0@gmail.com
