Is there a way to clear PCM codes with just pulling out the right fuse? If not how do you clear the codes. I have an OBD II scanner with a converter chord to OBDI but it doesn't track with the old OBD I system. I noted that the transmission codes can be cleared by puling the correct fuse for 30 seconds.
