Results 1 to 2 of 2
Thread: Clear codes with fuses?
    Jun 2020
    Seattle
    Default Clear codes with fuses?
    Is there a way to clear PCM codes with just pulling out the right fuse? If not how do you clear the codes. I have an OBD II scanner with a converter chord to OBDI but it doesn't track with the old OBD I system. I noted that the transmission codes can be cleared by puling the correct fuse for 30 seconds.
    Disconnect the negative terminal from each battery, and leave them disconnected for 30 minutes. That should clear the current codes, but there'll still be codes in memory (won't affect the systems, but are there to aid troubleshooting).
  1. Clear injector return lines size ?
    By DA BIG ONE in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-14-2007, 10:05
  2. Clear Headlight AND Corners for GMC
    By Ltrainracing in forum 2500HD/3500 Accessories
    Last Post: 10-01-2003, 07:31
  3. scratches in clear coat
    By markf in forum 2500HD/3500 Accessories
    Last Post: 07-12-2003, 13:10
  4. Looks like a all clear
    By mackin in forum Duramax 6600
    Last Post: 06-11-2003, 15:06
  5. Replies: 4
    Last Post: 05-20-2003, 18:03
