Thread: 6.2 vacuum pump to 6.5 vacuum pump??
    Jul 2020
    Default 6.2 vacuum pump to 6.5 vacuum pump??
    Will the 6.5 vacuum pump delete gear shaft fit and replace/delete the 6.2? The rear shaft in back of 6.5 block where the 6.2 vacuum pump is located, fit 6.2? I am thinking about swapping vacuum pumps to give serp belt less vibration.
    It will fit. You can also use an engine speed signal generator in its place (so you won't need it from the alternator). Dr. Lee, IIRC, did an extensive thread topic on that. Other options include using idler(s) in your serp setup. What is your need for a vac pump? HVAC? If so, that need is minimal, and can be operated with an electric pump.
    Jul 2020
    Thanks for that info! Need it for the th400. It uses vacuum for the shifting points.
    Gotcha. There are mechanical conversion options, but I haven't seen a good one yet.
  1. Vacuum pump/oil pump drive gasket
    By Robyn in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-13-2021, 12:25
  2. Vacuum Pump vacuum
    By Liftgate in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-29-2013, 09:44
  3. change v belt vacuum pump to gear driven vacuum pump
    By chrisc17cjs in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 02-12-2011, 04:01
  4. vacuum pump - oil pump drive or serp belt???
    By Mikey von in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 12-22-2009, 18:37
  5. Vacuum line from Vacuum Pump
    By noelb in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-19-2009, 07:11
