Thread: Can’t imagine going 600k on a oil change
    Dec 2005
    Klamath falls/keno Oregon
    Default Can’t imagine going 600k on a oil change
    I have over 400,000 miles on my stock truck change the oil every 10,000 miles
    60k not 600k
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    I think you have to install the oil filter adapter that uses a roll of toilet paper to get the full 60K out of it....
    60K (or 600 hours, whichever is less) is a maximum limit, dependent on following their product recommendations (filter changes, sample testing), for heavy duty use. Light truck use is limited to 25K, which may be reasonable, if their recommendations are followed. I know of more than one light/medium truck fleet that NEVER changes the oil, and just changes filters and adds oil to maintain the level. Their trucks don't fail at a higher rate than those who don't do that, regardless of the vehicle brand. Trucks are auctioned off at 100-200K miles. Savings probably in the millions over a vehicle life period (collectively), and likely a huge positive environmental impact.
    I talked to a guy some years ago who leased cars/trucks for many-many years. He said he always returned them when the lease was up, and he never serviced them while in his possession (except, I suppose to check fluid levels).
  1. coolant change, thermostat change
    By trucker582 in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 05-28-2015, 18:41
  2. IP change with out Eprom change
    By BUZZ in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 04-15-2004, 15:26
  3. IP change with out Eprom change
    Last Post: 01-06-2004, 05:21
  4. Oil change
    By mackey_62 in forum Duramax 6600
    Last Post: 04-09-2002, 11:58
