I notice the 6.5 is much quieter then the 6.2. Is it the rockers? Ip? Intake?
Normally the 6.5 with the electronic IP have a much harsher rattle.
They run a higher POP on the injectors.
The NA 6.2 SHOULD ACTUALLY BE A BIT QUIETER.
Now if the cold case advance is not shutting off they will rattle really hard.
Age. And a turbo. New 6.2 trucks were fairly quiet. Today, 6.2 trucks rarely have the original intake plumbing intact. The 6.5TD has a turbo, so it needed less attention in this department. A turbo is a noise reducer, in both directions. Many states don't require an additional muffler (as a means of noise control) if it has a turbo. The N/A 6.5 is every bit as noisy as the N/A 6.2, all else being equal.
Noise, as in "combustion rattle", is largely a function of injection timing. Over time, the 6.2/6.5 timing chain will stretch to a point that it loses a degree or more in timing advance. The result is less rattle. This is/was one of the arguments in favor of the aftermarket timing gear sets.
Contact
Lil Red - Duramax 6600 Conversion
Feature Articles
Product Reviews
The Diesel Page - 6.2L/6.5L Diesel Books
The 6.2L/6.5L Troubleshooting & Repair Guide
Duramax Diesel Conversion Guide
Duramax Diesel Service Guide - How to Replace Head Gaskets, Injectors, Water pump, and more - New!
My Photos
Ok thanks for that knowledge! The 6.5 I have is much quieter then any 6.2 I have heard.
