Welcome to the best GM diesel site
#1 were you putting oil in the power steering pump or brake fluid in the master cylinder?
#2 sounds like a ignition switch issue i had on my 98,but i would check your starter before jumping to the ignition switch.Did you try to activate the starter by applying power to the small terminals on the starter it's self?
Good luck,with some more information you should be getting a few more responces
