Thread: Its winter again Thermostats,
    Dec 2009
    In the North
    Cool Its winter again Thermostats,
    It's winter here in the toronto canada area,.7new glow plugs (duraterm bosch) most of you will know why only 7 ������
    and the old burb starts great.
    I put new T stats in 2 yrs ago, and the heat has always been 'marginal'
    It's difficult to wade through the internet BS these days,.
    So i'm looking for 2 195 stats that will actually work.
    i'd like A recommendation from some folks with experience and warm heaters!
    Part #'s would be a bonus.
    Thankyou!
    1999 chev suburban C2500
    300,000 mi
    Feb 2012
    Pauline, SC
    Kennedy Diesel comes to mind.....
    1993 Chevy K3500
    like us on Facebook
    I have dual 180's from Kennedy, but I also use the Lund winter front panels that snap into the grille of my Tahoe. For temps around 20 to 40 degrees F, I use 5 of the 6 panels to block most of the grille. For temps under 20 degrees F, I snap in all 6 which completely blocks all the grille. If I ever tow a trailer for more than a few miles, I just have to remember to pop out a panel or two to keep the engine from getting too warm. Otherwise, this works great for me here in the Midwest: cool thermostats for summer towing, and quick warm-up and cab heat for the winter!
    Dec 2009
    In the North
    i finally got fed up with the lukewarm heat,.
    i installed a pair of 12T92E stats.
    success,.
    looking at the old ones i surprised to find 1 was a 180, and 1 was 195,.
    Every winter my chev transforms to a 'gmc' as i have the shiney metal grille block off for a gmc,
  1. thermostats
    By Black Sunshine in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 12-09-2014, 23:20
  2. Thermostats
    By mhagie in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 12-20-2005, 21:11
  3. Thermostats, are they the same??
    By Billy V in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 04-10-2005, 06:32
  4. 180 or 195 deg. thermostats..
    Last Post: 01-27-2004, 10:04
  5. Using single rear wheels on Dually in Winter? Winter tips
    By A||||1||Robert W. Jones||Diesel Timing Light?||||5||||Stray Cat||00012887 in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 01-17-2004, 20:10
