Results 1 to 8 of 8
Thread: Another 506 bites the dust
    Jul 2020
    Default Another 506 bites the dust
    This is my 3rd cracked 6.5. I had high hopes for this one but darn it! Thought I should share... Btw it was said to have 44,000 miles on it... Would not have known it was cracked unless the crank was out. Moving forward.
    No worries. That'll buff right out. J-B Weld if it doesn't.
    Which # and side was that? Can't tell from the pics.
    Ouch! Now THAT'S a crack!
    Feb 2006
    That's just depressing as hell.
    Jul 2020
    Bubble gum works best I hear! Lol!
    I did not care to spend the brain power to count which one it was lol! Too depressed! It is already scrapped in the recycler.
    Understood.
    If you're doing it right, the best bubble gum is J-B Weld. Just don't leave it on the bedpost overnight (loses its flavor).
    That is exactly the same thing that happened to the engine in my old Dahooooley
    Looks to be the same location too.
    Large oil squirt holes and very sharp edges on everything.....A recipe for CRACKS.....
    So sorry to hear of this debacle......
    If it were me I would try to find an early 599 block (These are non squirt blocks)
    Actually with the poor luck you are having.....Have you considered one of the knock off's
    We have a couple of those still running around here....after several years...no issues.
    STAY AWAY FROM THE LATE 506 GM BLOCKS 1998-99-2000
    These had problems cracking the #8 cylinder at the top.
    The AMG BLOCKS are good.....
    The AMG blocks have a different Date code layout in the casting......
    2001 and later IIRC
  1. Another one bites the dust
    By 84 Convert in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 07-25-2007, 23:11
  2. Another One Bites The Dust
    By AC Bingel in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 05-26-2006, 18:12
  3. FSD bites the dust
    By N9Phil in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 09-11-2004, 15:34
  4. It Quit or Another one bites the dust
    By ronr in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 05-14-2004, 09:05
