Results 1 to 7 of 7
Thread: Sputtering after road bump
    Jan 2021
    Fort McMurray AB Canada
    Default Sputtering after road bump
    My 98 6.5 runs perfect until hitting a bump in the road ... about a kilometre later it sputters a bit and sometimes revs up a bit .... followed by running perfectly.... any help where to look is much appreciated !
    Welcome to TDP
    My guess would be somewhere in your fuel line between the tank and lift pump you have a slight air leak. When hitting a bump it jars it just enough to let in a tiny bit of ar and the injection pump is able to overcome that small amount.
    Just a guess mind you. But a place to start looking.
    Jul 2020
    Could be a loose wire or connector? I’ve had a starter wire hit the frame every time I hit a bump and it made the truck sputter.
    Both the above are possible.
    I tend to go with the air leak.
    Connect some clear plastic tube in the fuel return line to the tank.
    Connection is at the rear of the engine.
    Run a loop up by the wipers so you can watch it.
    Possibly need to leave the hood on the safety hook to allow the hose room to fit.
    The fuel return line should have a constant flow going back to the tank.
    After hitting the bump/a bump ...watch for a stream of bubbles.
    There are only a couple places that have flexible/rubber connections between the fuel tank and the lift pump'
    There is one other place that can be an issue....IN THE TANK AT THE SOCK BYPASS VALVE.
    Does this anomaly happen when the fuel level is low ...like 1/4 tank or less or does it matter ????
    If the issue is at low tank volume....then I would suspect the bypass valve may be bad and allowing air to suck in during the "Sloshing of the fuel " during the bump.
    Give things a whirl and see wassssssup.
    Good luck.
    Jan 2021
    thank you so much for your response.... much appreciated!
    Jan 2021
    Thanks for your response Robyn ... when I find the problem I will follow up here . Thanks again !
    You betcha.
    Keep us in the loop.
    Good luck
  1. 94 6.5 Hard Start, Sputtering Issues
    By 85spraybomb in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 07-22-2020, 20:26
  2. sputtering randomly, stalling sometimes
    By 94' 6.5 FS Blazer in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 02-10-2013, 10:51
  3. 98 6.5 sputtering
    By vaughn54 in forum 6.2L/6.5L Diesel - Upgrades & Service Questions Answered
    Last Post: 05-14-2007, 18:32
  4. Hard to start...Now sputtering.
    By Milkman in forum Duramax 6600
    Last Post: 01-19-2003, 11:28
  5. Hard to start...Now sputtering.
    By Milkman in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 01-11-2003, 14:47
