Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
Thread: Newbie to 6.5 have questions
  1. #21
    Dec 2003
    Yukon Canada
    Using it as just a pickup you will never know the difference.
    If you want to work it make sure you install a pyrometer and watch it pulling loads.
    Lots of 6.2's got turbo'ed with kits,or replaced broke 6.5's as you have found.
  2. #22
    Feb 2021
    Salt Lake City utah
    94F06895-8727-4C59-8F89-3FDDC61C6A54.jpgHere is a photo of my waste gate. Normally open or normally closed? On a second note the compressor wheel doesn’t look good. Are these easy to rebuild turbos? I’ve rebuilt some old air research turbos. Or does anyone have one they want to sell?
  3. #23
    Someone added that spring to make it a manual wastegate. Somewhere on this site there is a photo from about 20 years ago of an emergency repair I made when my vacuum pump failed 200 miles from home. It looks amazingly like yours. The spring is pulling it shut. Back pressure forces it open.
    [Edit] Found it...
  1. Newbie with questions
    By bforby in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 06-17-2007, 10:34
  2. Newbie Questions.
    By Chevmanx in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-09-2005, 15:41
  3. More Newbie Questions
    By cwlehner in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 05-12-2005, 12:52
  4. 6.5 Newbie Questions
    Last Post: 04-13-2005, 17:53
  5. newbie questions
    By James68352 in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-27-2005, 07:46
