Results 1 to 4 of 4
Thread: looking for injection pump mounting stud
    Jan 2020
    Jax Beach USA
    Default looking for injection pump mounting stud
    hi there
    i'm replacing my 90 vans injection pump and the top mounting stud is a little rough. Ive done a search and its hard to find one. I'm assuming that its got to be out there somewhere. maybe not.
    ...just thought someone might be a able to shed some light on this! Thanks!
    I've never seen them available as a separate piece. You may try matching one at the hardware/home store. Or clean it up (un-rough it). Otherwise, you'll be on the hook for a timing cover and the labor involved.
    Realistically, its function is very simple. If it's able to do that at a minimum, I wouldn't worry about it.
    Jan 2020
    Jax Beach USA
    Thank you. i feel better about cleaning it up and reusing it. it should hold just fine.
    i believe i found a part number - if its the same one used in the 6.5, in case anyone ever takes up the search
    GM 10024396
    Thanks for identifying it. There should be no difference between the 6.2 and 6.5 studs (the timing covers are interchangeable, except for the crank sensor). Unfortunately, it isn't available anywhere I could find. Fortunately, it is the same stud used in several places on the same engine, as well as many other GM applications (such as tranny adapter to engine), and that can be found.
  1. NEW ENGINE AND PUMP INSTALLED.PUM IS losing injection pump prime, is THIS A bad PUMP?
    By asabadin in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-04-2005, 06:37
  2. Vacuum pump (pod style) mounting gasket
    Last Post: 09-10-2004, 16:25
  3. Stud Girdle Kit and Oil Pump Questions (98+ pumps)
    By john8662 in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 05-30-2004, 13:24
  4. Injection Pump Mounting Flange Nuts Missing
    By tloomis in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-04-2003, 00:01
  5. Stud #1 - Stud #2 Fuse Box Question
    By 56Nomad in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 12-14-2002, 18:15
