I’ve done a lot more attempts than 20 times. The original pump
stopped delivering fuel as well. I bought this one from a man that
said he had it rebuilt then never needed it. 250 dollars I paid and it was
clearing cleaned up and had fresh paint marks on a few of the bolts/nuts
I think a problem with the pump is what I might be dealing with
the motor came from an 82 originally. I now have two 82 motors
I’ve had a pump go before and it was relatively easy to get running
would you recommend getting the pump rebuilt (1200 dollars here) or
checked first which is 400 dollars. Only one shop in lower BC that will
rebuild them sadly. Bd diesel doesn’t do it anymore
thanks so much for the help
