I had to replace my water pump and found my coolant crossover has an ear broken off. I know a lot of guys upgrade to the duel thermostat. Does anybody have a crossover part # 23500374 they would be willing to sell?
1994 Chevrolet K1500 Silverado Z71 6.5 Turbo
PMD relocated under front bumper
Home made lift pump mod
Home made glow plug controller mod
Snorkel removed
EGR blocked off
Check this out
https://www.ebay.com/itm/1994-1996-C...kAAOSwZopf4rBl
Thanks, I did see that and another one on Ebay that the seller offered $180 and free shipping. I was hoping to get one for a little less. I actually fond one for $125.00 plus shipping from a guy I know from a forum I used to belong too. I don't think I will find one cheaper than that, but I would like too.
Snorkel removed
EGR blocked off
Change your topic from "Help" to something like "Looking for unloved single thermostat crossover"
Time to cruise the pick a parts and see what treasures await you...
I did end up buying one for $145 to the door.
Snorkel removed
EGR blocked off
Broken "ears" on the coolant crossover...
Note to self... always use a flat washer under the crossover's bolts/nuts, to prevent damaging the crossover, like what is shown and discussed on page 83 of The 6.2L/6.5L Diesel Troubleshooting & Repair Guide. This Guide is far-far less expensive than a replacement crossover, and it's filled with hundreds of these sorts of time and money saving ideas.
Contact
Feature Articles
Product Reviews
My Photos
Thanks for that information. The ear was broken off when I bought the truck a couple of years ago. I packed it with RTV and have put about 7000 miles on it. I only took it back off because the water pump started leaking and one bolt for the timing cover is behind the bypass hose connector. Detroit Diesel division of GM could certainly have done a better job of design on the water pump installation. Oldsmobile V-8 water pump has dimples with threads in the timing cover, so they could have done something like that. Again thank you for that information, I will certainly be looking it over.
Snorkel removed
EGR blocked off
