Originally Posted by
DmaxMaverick
Welcome aboard!
If fuel is leaking from the weep hole between the mounting flange and the pump, the internal (rear) shaft seal has failed. The seal is replaceable, but requires disassembling the pump. If the pump is 100% otherwise, it would be worthwhile to have the seal replaced by a Stanadyne tech, at a fraction of the cost of an overhaul or reman. Your question may be best answered at a certified Stanadyne shop, by a certified Stanadyne tech. They can begin by testing the pump, to determine whether it's worth messing with.
