Thread: HELP!!!!!power steering connector from the steering column to the cooler........
    Jan 2005
    Denville,New Jersey
    Default HELP!!!!!power steering connector from the steering column to the cooler........
    is bad, and I can't find an adapter to connect to the steering column . Any body got an idea?
    What, exactly, are you trying to connect or adapt? With a line or fitting? What component to what component? Are you trying to replace a failed part, or add a new part?
    Dec 2010
    SE Texas
    Cicadas......or crickets.....
    '95 GMC Sierra 6.5TD C2500, reg cab, long box, 2x4, 4L80E, 3.73 ratio, VIN F, L65, 120K. Mods: DE 4" exhaust/crossover, WW2, PMD relocate, Dmax fan/clutch, HP air filter, Fluidampr, B&M Trans/Diff covers.
  1. Steering Column TSB?
    By jsmiracle in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 12-16-2007, 19:10
  2. Steering column problem?!?
    By Steve O. in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 09-20-2004, 07:52
  3. Steering column lubrication
    By Web in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 04-05-2004, 19:33
  4. Power steering cooler???
    By Dvldog 8793 in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-12-2003, 19:43
  5. steering column rattle
    By windjammer in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 04-28-2002, 16:56
