Thread: Loose shifter
    Feb 2003
    RAYMOND WA.
    Default Loose shifter
    I have a problem with my shifter, When I put it in park, It comes back at me and I have to push it forward to be able to remove my keys. Its like maybe a bad spring or a weak
    one, Can anyone help me. 2003 2500 hd
    ORDERED 1-15-03 ARRIVED 2-10-03= 03/2500HD/D/A/EXT.CAB LT/ LONG BOX/4X4/CARBON METALLIC/ONSTAR/ TTT CAMPER MIRRORS/WESTIN BOARDS WITH LITES/HUSKY FLOOR LINERS/PRO FIT FLAPS/ACCESS TONNO/LINEX BED RAILS/ FUMOTO OIL DRAIN VALVE,
    BEDRUG/BILSTEIN SHOCKS/ ISSPRO EGT GAUGE/RED LINE LUBE, BANKS EXHAUST BRAKE. GALAXY 929 CB/ WILSON 1000.KENNEDY LIFT PUMP.
    I had a gasser like that
    I tried adding a shim behind the spring which didn't help
    Sold the truck before i took another crack at it.I really can't see the spring being the problem...
    But
    It could be the spring, but more likely a cracked/broken pin-boss at the lever pivot. The pin may have backed out, as well. It doesn't take much at all to loosen enough to negate the spring. Pull back the boot and get a closer look. Check for excessive movement with it locked in P.
    Feb 2003
    RAYMOND WA.
    Top 2 coils of the spring was broke, GM don't the spring had to replace the control. GM part #26092432. Problem fixed. thank you
  1. Shifter notification
    By DIESEL/VETTE in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 11-02-2016, 13:51
  2. Loose Gear Shifter
    By Defender in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 08-16-2013, 10:38
  3. 08 lmm tap shifter
    By gspman in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 05-11-2013, 18:51
  4. shifter
    By mutlu in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 07-28-2003, 18:25
  5. 4wd shifter rattle
    By GreenScape in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 06-17-2002, 16:51
