Results 1 to 2 of 2
Thread: Spark plug question
    Dec 2005
    Klamath falls/keno Oregon
    Default Spark plug question
    Wife has a 2003 GMC 1/2 ton with a 323 V-8...manual says to use a 41-974, all the information
    Says this plug is no longer in use, and to use a 41-110...went to e-bay and the info provided says that plug won’t work
    On her truck..
    Thoughts?
    Hummer wheels :^)
    Kennedy dual lift pump
    Banks air intake
    I wouldn't trust eBay for fitment. They get it wrong too often, and the specs depend on whatever the seller inputs.
    I'm showing ACD 41-962 Platinum for that truck/engine, gas or Flex Fuel. The OEM Iridium plugs are no longer available from ACD. If you want Iridium, use Bosch (#9602) or NGK (#7397).
  1. Glow plug question
    By Newty in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-31-2012, 08:07
  2. Oil pan plug gasket? Dumb question?
    By DickWells in forum Duramax 6600
    Last Post: 05-08-2006, 18:42
  3. 6.5L Glow Plug Question
    By 2Lane in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 02-03-2006, 16:01
  4. Glow Plug Wires Question
    By DennisG01 in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-26-2006, 20:09
  5. Another Plug in question
    By rtquig in forum Duramax 6600
    Last Post: 12-09-2002, 14:32
