Results 1 to 2 of 2
Thread: Trans oils change...
    Dec 2005
    Klamath falls/keno Oregon
    Default Trans oils change...
    I have 45,600 miles since my last oil change..none of the oil on ebay will work
    In my trans, or so says the seller...
    I would like to change the internal filter along with the oil and external oil filter
    Can someone post a ebay link to the proper oil for my 06
    Thanks..
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    The ATF is more simple than that. It requires Dexron VI.
    The internal filter, according to Allison, is an overhaul replacement item. It requires no service between overhaul cycles. The same applies for medium duty use, so your pickup isn't overworking it. The Control-Main spin on filter and fluid is all that needs service until you break it.
    Just curious, but why eBay? Dex VI is on the shelf at any Walmart or parts store. I doubt you'll save any money shipping a genuine product to you.
    Lots of it on eBay:
    Ebay Dexron VI search
  1. oil additive and trans oil change
    By coxfmly in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-14-2012, 18:03
  2. When to change trans fluid?
    By LEE BROWN in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 05-11-2009, 18:27
  3. Allison Trans. Fluid When to change it?
    By Randy01 in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 01-03-2004, 22:18
  4. Would like to change out auto trans for manual
    By jeffreydmet in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 11-16-2003, 19:41
  5. Trans fluid change directions?
    By TURBOJOE in forum Duramax 6600
    Last Post: 04-28-2002, 15:19
