Results 1 to 20 of 28
Thread: Starter laboring ....now not even clicking ~
    Mar 2002
    Lecanto, FL
    Default Starter laboring ....now not even clicking ~
    I didn't like the way the alternator was charging so I swapped it out.
    Charging back up to 13.5 +
    Seemed fine than a couple hundred miles I felt the starter was laboring.
    The batteries showed a little week on the load test so, throw new ones in I did.
    New batteries didn't make much of a difference.
    Then I find passenger side block ground had worked its way out of it's crimp ~ repaired.
    I got a few good starts, & good when warm. then back to starter laboring.
    All connection to battery have good clean seats with Jam nuts.
    This morning..... starter wont crank at all....
    The solenoid may have clicked a few times at first.....
    But now nothing no clicks (even put a battery booster on)....everything lights up on dash like she's ready to go at glow but nothing.
    Fuses all appear good.
    I'm ready to drop the starter...
    Question?
    Is there anything thing I can test before dropping starter /solenoid?
    Thanks`
    C1500 1995 Turbo Diesel Automatic 480 (Guessing it's the Solenoid)
    96 1500 6.5 Silverado
    81 Malibu ~ 75 Vega Wagon
    Lecanto, Florida
    Starter has given it's all
    Check your battery voltage. Something may have discharged your new batteries overnight (including your new alternator or new battery(ies)). If that did happen, the new batteries will never be new again. Deep cycling starting batteries kills their lifespan and response. Once or twice will usually see them bounce back to good service. More than that and they fall off quickly.
    Recheck the connections and grounds (block, frame, and block to firewall), and check the starter solenoid lug connection (common suspect).
    Mar 2002
    Lecanto, FL
    wouldn't the charger on boost / start at least klick the solenoid if the batteries got 'hurt"?
    Lecanto, Florida
    Mar 2002
    Lecanto, FL
    thanks for the input
    I'll be double testing & dive into the wheel well soon.
    Opinion on the 9052 power master?
    Lecanto, Florida
    Quote Originally Posted by Low_Bridge View Post
    Theoretically, it should, but not always. It depends on how hurt, hurt is. A gradual worsening of a dragging starter, then clicking, then no clicking, suggests a loss of electrical. A bad starter won't stop the solenoid from exciting. If the solenoid lug is loose, it won't matter much or what you connect to the battery terminals. It won't carry the load current, and eventually carry no current. Your starter maybe bad, but checking the lug and other connections costs nothing but time. Oftentimes, changing out a suspected bad starter corrects other failings, such as a poor connection or bad solenoid, wrongly confirming you replaced a bad starter.
    Feb 2012
    Pauline, SC
    Cables, ground connections need to be replaced it seems, the bigger the wire size the better for + & - wires.
    1993 Chevy K3500
    like us on Facebook
    Mar 2002
    Lecanto, FL
    So I see the turbo piping make this a not near as fun. She's DOA outside of the garage blocking the 2 car lift (occupied). So driveway a driveway R&R appears to be my fate.
    I'm I correct that the fender well DOES NOT need to come out/off with the correct tools? My exhaust exiting turbo is aftermarket & I believe a little bigger.....
    Lecanto, Florida
    TO MAKE THE JOB EASY
    Remove RF TIRE
    Remove the rubber splash apron.....You can sit on a bucket and access the starter wires and the support bracket easily.
    This trick also makes the glow plugs 2-4-6 really easy to change too......
    Mar 2002
    Lecanto, FL
    First finding:
    Top Bracket bolt fallen off:
    Question: size for top bracket bolt?
    Arcing on solenoid wire (activation)
    Mar 2002
    Lecanto, FL
    Found this: 8mm x 1.25mm, 20mm long
    Lecanto, Florida
    First finding:
    If it's arcing, it's loose or the terminal has lost integrity. Either can/will cause all the symptoms you've experienced. If it's just loose, clean the connection and tighten it. If it's the terminal, you'll have to crimp a new terminal on the (newly stripped and clean) end, or replace the cable.
    Mar 2002
    Lecanto, FL
    Dropped the starter & it's an ugly old beast .....looked like it had a yellow junk yard number on it.
    Solenoid seems to be intermittent on the bench.
    Lecanto, Florida
    Mar 2002
    Lecanto, FL
    Upon inspection I don't find any arcing on the starter bracket that was loose.
    Taking loose the solenoid & pulling it back & at the snot, the Bendix actually look ok ~
    A napa starter is 1 day out, O'rielly today & Powermaster on Friday...
    Question: What's my bench test to be sure it was my solenoid ?
    Shouldn't I do some sort of ignition switch test?
    (BTW ~ My Auto electric guy has only offered my new stuff last few times)
    Lecanto, Florida
    Mar 2002
    Lecanto, FL
    Update -
    After spending too many hours trying to approach the Solenoid bolts & bracket from both the side & from front (above & below motor mount had to be my technique)
    I resorted to dragging a milk crate under the starter, dropped the stater bolts & flywheel cover & had it out in 10 minutes letting it rest on the milk crate & once the starter bolts were out the angle let me easily reach the wires.
    Hooked up batteries ( made sure hot was clear ) tested the solenoid wire when the key was turned to start.
    I got power at the meter every time.
    Ordered a PowerMaster 9052 & ARP Bolts.
    Hating to have my Diesel down with a the Tropical storm bearing down ~
    Lecanto, Florida
    Getting at the starter wires, solenoid and other goodies in there are a breeze with the access through the wheel well opened up.
    Sit on the milk crate and undo the main cable and such,..
    Mar 2002
    Lecanto, FL
    Robyn, mean the splash apron, not the metal wheel well itself?
    I failed at accessing it there? Did read your post above...... hmmm
    Where did I go wrong?
    Lecanto, Florida
    Yes......The rubber apron.
    Once the apron is out of the way there is plenty of room between the top of the frame and the metal inner fender to reach the electrical connections on the starter.
    This access point also allows easy access the glow plugs 2-4-6 as well.
    The bolts on the starter and the actual removal must be done from below......
    Good luck.
    Mar 2002
    Lecanto, FL
    So the Power Master has been in a while I just now gettin in the loop.
    When cranking this one is louder & I feel there is a grind. I shimmed it this morning. Dose not seem to sound better?
    When it's initial firing is when it seems to grind? Can you you hear? or do I need rerecord from under the truck?
    http://jadaddio.com/6.5/Starter_6.5_.mp4
    Lecanto, Florida
    I listened to the video.
    The first chattering noise is not "Grinding" it is the solenoid chattering due to a voltage issue....Poor connections or bad cables........
  1. clicking noise
    By Diesel 4 blood in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 05-27-2013, 15:30
  2. Clicking when starting
    By Rider1965 in forum Duramax 6600
    Last Post: 10-30-2012, 12:15
  3. Clicking Relay, I think
    By winemaker in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-07-2007, 08:43
  4. Starter Clicking....
    By FrankieRider2 in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-11-2005, 16:02
  5. Mysterious Clicking
    By MAXed Out in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 04-26-2002, 13:38
