Results 1 to 7 of 7
Thread: Tranny oil change..
    Dec 2005
    Klamath falls/keno Oregon
    Default Tranny oil change..
    Is there a sticky or a link on a how to?
    I have 71,000 miles since my last change..
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    The "how to" has been discussed several times. We probably should make one a sticky. Are you doing a drain/fill, or a full flush? They are detailed here, but I don't remember where, short of searching for it. I've written about it several times, including a step-by-step for a full flush.
    Dec 2005
    Probably a drain and fill..my trans has about 200,000 miles on it, it’s a rebuilt..
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    I just typed up a lengthy post for service an ALLISON tranny, then realized, you have a ZF. Just drain and fill. In the future, perhaps a bit sooner. 71K is a bit long. Pay attention to what comes out of it, and on the drain plug. Use a quality synthetic fluid (Mobil 1, Amsoil, Redline, Royal Purple, etc.).
    Dec 2005
    Thanks....
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Dec 2005
    Did the change, dropped the pan..there was a dusting of metal on both magnets barely noticeable, and the oil was red like it was new..
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    That sounds good. A little "dusting" is normal and expected, especially for the miles. Chunks or shavings would not be good.
  1. tranny change out
    By danjil0 in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 07-14-2012, 16:43
  2. tranny fluid change
    By bwoody in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 11-21-2006, 19:07
  3. Tranny filter change
    By maytagman in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 08-26-2005, 07:21
  4. for those who change tranny fluid
    By sspm1 in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 10-11-2002, 03:41
  5. Tranny Oil Change
    By hammer in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 06-11-2002, 12:10
