Page 1 of 10 12345 ... LastLast
Results 1 to 20 of 199
Thread: 6.5L Turbo Diesel Blazer Project
    Talking 6.5L Turbo Diesel Blazer Project
    This is the way the Blazer's 6.5 looked this morning, after spending yesterday installing new cam bearings and setting the crankshaft into the block. The engine shop that did the machining already installed new cam bearings, but they weren't installed with the oil holes clocked correctly. So, they had to come out and another new set installed. Since this photo was taken, all of the pistons/rods have been installed along with the 16 roller lifters and oil pump. I also looked through the various and sundry boxes of parts. Haven't found them all yet, but it's early! I wasn't the one who disassembled the Blazer, so my foggy memory and the GM service manuals will have to suffice with the re-assembly process.
    Onward and upward... My daughter helped me a few of the weekends during the two Duramax head gasket jobs. After a couple of weekends, she looked over at the 1994 Blazer, and asked what I was going to do with it. Long story short, it's now hers, and we'll work together to make it go. She's a trooper, likes learning and enjoys spending time with her dad. Plus, she'll have a rig to haul a kayak and do some light camping with her friends.
    Looking good, Jim! I'm glad to see another Blazer being saved.
    Thanks Casey,
    Plans include a roll-on bed-liner coating (like Durabak) below the belt line, on the fender flares, and applied to the front 6-8" of the hood and 6-8" of the roof. And we'll install some good looking/tough mud flaps and small/good looking steps. It'll be driven on winter roads with road de-icer, so the underneath will get some rust prevention treatment. Along the way, it'll get new steering, suspension and brake parts to make it drive like new. Oh, and Sarah tells me it'll get new audio components... Vroom sounds aren't quite enough...
    LOOKING GREAT
    I wanted one of the GMT400 Class Blazers (Diesel) and could never find one.
    Looks like a good start! I'll be following to see your progress.
    Here's mine:
    Diesel Page Member #2423
    Quote Originally Posted by trbankii View Post
    Here's mine:
    Nice!! But, no holes in the bumper?
    It's interesting that GM put fender flares on their 2-door diesel Blazers/Tahoes. I wonder if they also put in heavier torsion bars?
    That's come up before. Both my 6.5's were purchased used and neither had the "correct" front bumper when I got it. I have no way of knowing if they came OEM that way or if the front bumpers were damaged and just replaced with what was available from the junkyard?
    I had heard that some of the diesel 2-door Tahoe/Yukons didn't have holy bumpers. An oversight or cost saving strategy? Who knows. Ours is a 1994 model, and I believe it has the original front bumper. I replaced the original rear bumper back about 2000 when we owned it the first time (it had taken a small hit in the right corner). Not having holes isn't a big deal cuz these vehicles weren't used to tow heavy, but the holes are an icon of sorts.
    I had heard that some of the diesel 2-door Tahoe/Yukons didn't have holy bumpers. Not having holes isn't a big deal cuz these vehicles weren't used to tow heavy, but the holes are an icon of sorts.
    The holes in the bumper is what I first spotted when I purchased my Tahoe back in 2005. We were driving home from church, I spotted the holes in the bumper on the vehicle in a dealer's lot; I first thought it must have been a Suburban, but when I turned around to go back and check it out, discovered it was a 2-door Tahoe. I went back the next day and bought it!
    Lightbulb
    The engine is slowly going back together - waiting on the heads now. They have been at the engine machine shop for about 2 weeks, to get a valve job. It's interesting to note that the exhaust valves get stem seals and the intake valve stems just get o-rings.
    The heads are the small port variety, which is what this particular 599 engine had from the factory. Should be better for fuel economy, but I know this 3.73 geared vehicle delivered about 15-17 mpg when we owned it the first time about 20 years ago.
    This image shows the Fluidampr installed. I've had this particular damper since I did the article on them years ago - had never been installed on an engine - I used it for a photo prop back then. The paint fade doesn't affect it in any way, but it's odd how the once jet black coating turned sort of olive drab over time.
    I knew from reading several comments from those who had installed a Fluidampr on their 6.5 that the interference fit over the crankshaft was pretty tight, so I baked this one in the oven for over an hour at ~225 degrees before attempting to install it. While the service manual didn't indicate that a lubricant was necessary, I coated the crankshaft snout and the inside of the hot damper with motor oil before beginning. It went on pretty easily for the first inch or so (about halfway), then it got tight... The GM service manual instructs those installing a damper to use a "mallet" to drive it on. I had my fab/welder guy make an installer for me, but I soon discovered that the PVC pipe I was using under the all-thread wasn't the best choice. Should have used a steel pipe. So... my fall back was a 6" long block of wood and a BFH (Big French Hammer ). Did fine.
    The cam bolt was torqued to 125 ft-lbs and the damper bolt was torqued to 200 ft-lbs. I would have liked to have had a timing gear set, but instead installed a new chain from uniquediesel.com. There was about 1/4" or a bit more slack in the chain, which is pretty good for a new chain.
    Also shown in this image is the newly installed water pump... an "HO" type. I've been saving this water pump for a long time. It had been a new take-off that Peninsular sent to me years ago. I actually have quite a few new or like new parts that I've been saving for a long-long time that'll now find a home. Jim
    Dec 2003
    Yukon Canada
    Here is my blazer project
    Doing a yard cleanup at my business,it's all mine now as i just paid out the X for her half of my life.I have a big yard out back of my shop where there was 100+ vehicles accumulated after 25 years of running the shop.
    I have plans for the middle of the lot so i am going to limit myself to vehicles double parked down the one property line.
    Then my straight body keepers along the back property line.
    This blazer had been sitting in the back for about 12 years,it's an 81.The diesel still turns over no water in the oil.The body is going to the dump,engine going into dry storage. I have another rust free califonia blazer that got hit hard on the hinge side of the drivers door,that frame is bent so the rust free body is going on the straight frame,and if i don't find a nice blazer at least the pieces i have will make a good start.Plus i reduce the keepers by one.blazer d.jpgblazer b.jpgblazer e.jpgblazer f.jpgblazer a.jpg
    Thanks for saving what can be saved. I know a guy here in Montana who saved a 1965 Mustang convertible... a valuable one that had a famous life, but was burned out totally. The VIN plate survived, so he built a car around it using as many OE parts as he could. Jim
    Dec 2003
    Yukon Canada
    I will continue to save what i can...
    I have a soft spot in my head for the GM diesels
    This summer i have been given a couple GM Diesel trucks that their owners had enough of
    One a truck i almost bought when it was a year old,PO thought he destroyed the tcase,91 4x4,the other a 3500 dump truck with 19.5 tires,both trucks run and still have usable life in them.Since i got my first 6.2 and joined the site i have accumulated a good stash of parts and running engines,i have 6 trucks that haven't been on the road in a while that have the GM diesel in them.
    Here are the most recent pics of my Blazer (Tahoe):
    Mine originally came with a set of factory running boards/fender flare combos, but I swapped them out for the black fender flares. I originally purchased the Tahoe back in 2005 for my wife, but since then I have inherited it and made it more of what I thought it should be like.
    2005, when we purchased it with 174K on the odometer:
    She's been a very reliable daily driver over the past 16 years, accumulating a total of 376K miles until she finally blew a head gasket a few weeks ago. I've got her torn apart and hope to start the reassembly process next week.
  15. #15
    ... my Blazer (Tahoe):
    Casey,
    Just curious, did you drill holes in the front fenders to mount the factory fender flares? I'd like to install these flares to Lil Red. Thx
  16. #16
    Casey,
    I used self-tapping screws. I installed the flares, then removed the screws, put silicone in each hole, and then reinstalled them. If you're not careful, mounting the flares can cause rust issues.
  17. #17
    Geneva, IL
    My first purchase in the 6.5 world, I thought my used 3/4 ton had had running lights removed from those holes...
    Rich Phillips
    Member #27
    2019 K-2500 Crew Cab Z71
  18. #18
    Red face More 2-Doors
    Here is a selection of photos from various Rendezvous we had where a few 2-door Yukons and Tahoes attended. These had holes...
    Mark Perina's red 2-door Tahoe. It was so nice! Maybe it was the red...
    This white Yukon belonged to member Ron Wong from near Tucson. Here, we were doing a little light trail riding here in Montana during our 2000 Rendez.
    The above was taken near Grand Rapids MI at our 2006 Rendezvous. Something is going on here. Guess who the guy is wearing the black shirt.... (hint, it's not me).
    Is that Dave? Reminds me of a joke about North Dakotans... "How many North Dakotans does it take to change an injector?" We love North Dakotans here in Montana. They have the same sort of jokes about Montanans... This was taken in the parking lot of Peninsular Diesel in Michigan. Their operation was like a candy store for 6.5 parts. Who could resist upgrading something?
    Getting the dampers on can be easily accomplished using a Threaded rod screwed into the crank shaft (Bottomed out in the thread) and a heavy washer over the end of the damper.
    Install a nut on the thread rod and wind that bad boy on there.
    Liberal coating of never seaze on the threads and under the nut.
    Metric thread rod can take some searching....but is available.......
    IIRC I was in a hurry and just grabbed a new metric bolt at the ACE Hardware...Cut the head off...then turned up a little sleeve to slip over the bolt....Then welded the metric bolt to the sleeve and added a length of SAE thread rod to do the work.... FINE THREAD...
    Once you have these little helpers....they can find a home in the tool box for another time...
    Right along side the puller used to get the damper off....
    Looking great Jim
    Going to be sweet to see this old girl running again....
  20. #20
    Robyn,
    I had my fab guy make this for me a while back, along the lines of what you mentioned. I gave him an old damper bolt (I had chased the threads so it wouldn't damage the crank threads), a nut and a length of all-thread. He TIG welded it together for me.
    I would run the 18m bolt all the way into the end of the crankshaft by hand. The problem was that as you get the damper over halfway on, the big washer in this pic butts up against the nut/allthread, so I needed a sleeve to go over that. I thought a short length of PVC pipe would work. I didn't - not strong enough. I should have had a short length of steel pipe. Jim
  1. 85 k5 blazer 6.2 turbo conversion
    By jasonh in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-18-2017, 10:33
  2. Cucv Blazer Turbo 400 same as Civilian
    By darkroad in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-22-2007, 19:55
  3. My 6.2L turbo project update
    By arveetek in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 06-29-2004, 13:37
  4. How about a Twin Turbo 6.5 in a 73-74 Blazer?
    By Uncle Wally in forum 6.2L/6.5L Diesel - Upgrades & Service Questions Answered
    Last Post: 03-06-2004, 15:08
