Results 1 to 4 of 4
Thread: Wanted - AC Brackets for 6.2 (top driver's side mounting)
    Aug 2021
    Los Angeles, CA
    Default Wanted - AC Brackets for 6.2 (top driver's side mounting)
    Hello, I am looking to purchase the mounting brackets and hardware for an air conditioner compressor for a 6.2 engine. I am attaching a picture that shows the parts I am hoping to find. There are:
    - four brackets
    - a "support"
    - the AC hose (that bolts to the compressor)
    - a handful of nuts and bolts.
    - I would be willing to purchase the compressor as well, but not needed
    My van originally came without an AC. I recently bought another van to swap the dash and AC components. The "donor" was a gasser and the compressor/brackets are different so I am looking to find the parts I need to complete the project. The compressor mounts on the top driver's side of the engine. Thank you!AC Parts Diagram with notes.jpg
    1992 Chevy G20, 6.2 NA
    I have an 81 6.2 that i just pulled from a blazer that burnt.
    It had AC.
    I would sell the bracketry if it works for you.
    I did notice the bracket that is on the exhaust manifold is a little different than the picture.it is shorter.
    No hose or compressor
    Aug 2021
    Los Angeles, CA
    Thank you for responding! I will send you a private message.
    Aug 2021
    Los Angeles, CA
    Yukon, thank you for reaching out. That was very cool!
    Unfortunately the brackets that Yukon had were not going to fit my vehicle and I am still in the market to buy a set that will. Thank you.
  1. Wanted 6.2 or 6.5 engine brackets '88-'95
    By oilburnertoo in forum TDP Classified ad forum
    Last Post: 12-17-2009, 18:39
  2. IFS Oil leak Driver's side
    By JohnC in forum 1982-2000 C/K Truck & SUV Chassis & Drivetrain
    Last Post: 02-20-2007, 15:40
  3. IFS Oil leak Driver's side
    By JohnC in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 02-12-2007, 13:32
  4. Help ! Accessory Mounting Brackets
    By twano in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-04-2005, 07:50
  5. Low Air Flow Driver Side Vent
    By TC in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 08-14-2002, 12:06
