Results 1 to 2 of 2
Thread: No black smoke?
    Jul 2020
    Default No black smoke?
    Weird! This 6.5 Optimizer I installed with a 4911 injection pump and 3-7 psi lift pump does not blow any black smoke when I accelerate heavy. Is that good? Or is fuel too lean?
    Turn up the pump. It should puff a bit of gray/black until the turbo spools. There is no "lean" in a Diesel. The intake air is essentially unrestricted, so less fuel is just less power (and/or smoke). It doesn't have nearly as restrictive A/F ratio requirements as a gasser.
  1. Black smoke?
    By vsandme in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 09-11-2012, 13:46
  2. Too much black smoke
    By dheavychevy38 in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 07-28-2008, 12:49
  3. 94 Black Smoke
    By Splitrimz in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-05-2004, 01:34
  4. Black Smoke
    By DAYSU in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 12-21-2003, 16:27
