Thread: Tires!
    Thumbs up Tires!
    I recently replaced a set aging Cooper tires that had a somewhat aggressive tread pattern with a set of Toyo Open Country H/T II tires that have a 10 ply rating and a more highway oriented tread pattern. Both the old and the new tires were sized 265/75R16. I really disliked the Cooper tires because of the road noise, and had to have something quieter. I bought a set of Michelin LTX tires for this truck back some years ago that I liked, but... they are more expensive and are not stocked by our local tire shops.
    The Toyo tires are highway oriented, but I suspect the edges and siping in the tread pattern will provide a good grip on our coming winter roads. Best of all is that the tires are virtually silent at any speed. Take your foot off the go pedal, and all you hear is a little wind noise around the cab - no tire noise. The humming drone that so annoyed me is totally absent, and the balance of these tires is perfect. Total out-the-door cost at our local Les Schwab was just over $1100.
    When the truck is unloaded, I run 60-psi in the rear and 70 in the front, to produce a flat contact patch with the road. I'll adjust the pressure as needed to produce a flat wear pattern. And, if I use this truck to tow/haul, I'll adjust the tire pressure to better suit the load.
    You must have had the Cooper SSTs. The ST isn't as noisy. I had the Michelin MS2 and they were very quiet.
    Dec 2005
    Klamath falls/keno Oregon
    I ran the Tokyo’s and got 60k out of them I ran at least 5 sets of them, then a Les Swab guy talked me into there high mileage tires, they won’t be going the distance. Not even close.
    Hummer wheels :^)
    dual lift pump
    Banks air intake
  1. Re. trailer tires vs. truck tires, JFWIW.
    By DickWells in forum Towing - 5th-Wheels & Travel-Trailers
    Last Post: 06-05-2012, 18:59
  2. Trailer tires or LT tires?
    By moose1 in forum Towing - 5th-Wheels & Travel-Trailers
    Last Post: 04-12-2004, 04:37
  3. BFG Tires
    By DieselDixon in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 09-11-2003, 16:54
  4. '03 QIZ Tires
    By tysmith in forum 2500HD/3500 Accessories
    Last Post: 06-28-2003, 19:32
  5. Nitto Terra Grappler Tires / Interco TrXus Tires
    By gardnerteam in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 06-12-2002, 05:25
