Results 1 to 5 of 5
Thread: Drive train question
    Feb 2003
    RAYMOND WA.
    Default Drive train question
    On my 2003 2500 duramax, in front of the rear end between the universal joint is a large round metal piece, around 8 to 10 inches in diameter, what is this for and what does it do?
    ORDERED 1-15-03 ARRIVED 2-10-03= 03/2500HD/D/A/EXT.CAB LT/ LONG BOX/4X4/CARBON METALLIC/ONSTAR/ TTT CAMPER MIRRORS/WESTIN BOARDS WITH LITES/HUSKY FLOOR LINERS/PRO FIT FLAPS/ACCESS TONNO/LINEX BED RAILS/ FUMOTO OIL DRAIN VALVE,
    BEDRUG/BILSTEIN SHOCKS/ ISSPRO EGT GAUGE/RED LINE LUBE, BANKS EXHAUST BRAKE. GALAXY 929 CB/ WILSON 1000.KENNEDY LIFT PUMP.
    Vibration/harmonic damper. It helps prevent damaging (and possibly annoying) vibration and harmonic frequencies generated by the axle from transmitting through the shaft.
    Feb 2003
    RAYMOND WA.
    Thank you.
    Question
    Road salt and de-icer can affect these dampers by eating away at the cast iron/steel components. Not sure what to do about that, or how extensive a repair it might be to fix it. Anyone replace one of these?
    The damper is part of the pinion yoke (not separable), and a repair would simply be a replacement of the yoke. If the damper fails due to corrosion, the shaft and other nearby components (axle, springs, etc.) should also be suspect. The damper appears, to me, to be the least of the worries in that area. Something serious would likely fail long before it became a factor.
  1. Drive Train Vibration
    By Smitty1 in forum 1982-2000 C/K Truck & SUV Chassis & Drivetrain
    Last Post: 07-11-2007, 12:06
  2. Drive Train Vibration???
    By Smitty1 in forum 2500HD/3500 Accessories
    Last Post: 07-03-2007, 08:36
  3. Drive train oil levels
    By BSKI in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 10-11-2006, 10:14
  4. Swap 6.5 drive train for 350 drive train?
    By Scott Royse in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-16-2005, 10:35
  5. clunk in the drive train ??
    By REC06 in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 02-06-2003, 04:53
