Looking for '94 K2500 oil filter adapter o-rings/gasket etc. From what I've read (3) O-rings make up the seal. Any leads on a vendor appreciated. Thanks again!
Find a hydrolic shop in your area and take your orings there,they should be able to fix you up.
Get some gasket paper from a parts store to make any gaskets.
Rockauto.com shows them. Fel-pro #ES73229.
2006 Chevy K2500 LLY Duramax/Allison Crew Cab!
1996 Chevy C2500 6.5 auto Ext. Cab LB
Leroy's kit has everything included for both the older and newer types.
1995 K2500 Suburban (aka The Hulk)
