Thread: ISO 6.5 Oil filter adapter o-rings/gasket
    Jan 2020
    Trabuco Canyon, CA.
    Default ISO 6.5 Oil filter adapter o-rings/gasket
    Looking for '94 K2500 oil filter adapter o-rings/gasket etc. From what I've read (3) O-rings make up the seal. Any leads on a vendor appreciated. Thanks again!
    Dec 2003
    Yukon Canada
    Find a hydrolic shop in your area and take your orings there,they should be able to fix you up.
    Get some gasket paper from a parts store to make any gaskets.
    Brighton, CO, USA
    Rockauto.com shows them. Fel-pro #ES73229.
    2006 Chevy K2500 LLY Duramax/Allison Crew Cab!
    1996 Chevy C2500 6.5 auto Ext. Cab LB
    May 2020
    Redwood City, CA
    Leroy's kit has everything included for both the older and newer types.
    1995 K2500 Suburban (aka The Hulk)
  1. Fuel Filter O-rings
    By JTodd in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 11-29-2010, 00:15
  2. oil filter adapter
    By 5.7L oldsdiesel in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 02-09-2006, 08:29
  3. oil filter adapter
    Last Post: 02-07-2006, 17:16
  4. Oil filter adapter
    By N9Phil in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 05-12-2005, 12:03
  5. OEM to CAT Filter Adapter
    By Corndog in forum Duramax 6600
    Last Post: 09-26-2003, 17:24
