Thread: 84 6.2 Sidewinder sat for 15 years Help?
    Jul 2020
    Default 84 6.2 Sidewinder sat for 15 years Help?
    I am thinking about buying a 84 6.2 with sidewinder truck. It’s been sitting 15 years or more. Aside from changing all the filters and fluids, batteries, and priming the system, what else should I do to try and get this to start?
    Myself i would pull the glow plugs.To both check to see if they work,are swollen,to check the glowplug system.and to crank it over easy till you get fuel from the holes
    Jul 2020
    Think WD-40 in the cylinder would help too?
    It will not hurt it,
    If you are doing it for the rings try some marvel mystery oil,or tranny fluid
    Opps i meant to say gender neutral sliptivity juice.
    ....or tranny fluid
    Yes, we must be careful, lest ye be canceled.
  1. WTB: 6.2L Banks sidewinder kit
    By Corpse in forum TDP Classified ad forum
    Last Post: 03-02-2012, 16:02
  2. WTB - Banks Sidewinder Turbo Kit
    By Subzilla in forum TDP Classified ad forum
    Last Post: 01-29-2008, 14:10
  3. Sidewinder Type-D, 8.225 @ 164.67 MPH
    By PeterT in forum Duramax Diesel Performance Shop
    Last Post: 12-06-2007, 10:25
  4. banks sidewinder on a 6.5
    By micky_blue in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 07-31-2007, 16:47
  5. Wanted, Sidewinder turbo
    By Dezman125 in forum TDP Classified ad forum
    Last Post: 08-14-2004, 08:11
